c++ runtime does not charge with autodesk design review
  • Thread starter Thread starter Micim
Micim
I tried to install the autodesk design review, but I do not charge visual studio 2010 c++ runtime. Can it be that I downloaded the 32b version having a 64b? if I find the 64b one? I've done some research on the net, but in the end it always sends me back to version 32b. I also did a search on the forum, but I didn't find anything.
Bye.
if I'm not mistaken when that error happened even in the offices where I worked, the softwarista had to first uninstall visual studio 2010 c+ runtime from the windows control panel and then install design review.
the design review installer already has a version of visual study c++ runtime...you see that the 2 "things" go into conflict.
I don't know, I've never done it practically.
I hope I helped you.
Riciao!
Thank you both.
Tristan I tried freewheel, but in reality my problem is that with an old version of autocad (I think 2012) I could open a dwf and make a cut to be inserted into a panel.
now (use autocad lt 2014) I can insert the dwf in a dwg file, but I am not able to create the crop.
I hope that autodesk design review allows me to create the necessary crops that are also slender to manage.
What do you say, utopia?
design review I do not understand that it allows you to cut out the dwf. anyway with autocad lt 2014 by memory I think you can create a crop contour on external references. .
