calandrature
  • Thread starter Thread starter braunfish
What is the best way to displace a pipe in a set?
No, better explain why you want to get in the room together?
and then, roll a sheet to get a pipe or fold a desired radius tube?
and again, does the pipe weigh it from the center contained or not?
The answers change...
You're right.
-I had to fish from the contained center.
-the tube will be a part that will be part of a welded assembly
- the tube is formed by a straight portion, a curved portion with a wide radius, a straight port.
You're right.
If you want your pipe like ipt, you have to create it with a sweep in the space part, if you want to draw it from the cc, then you should create the skeleton sketch in the axieme, make the tube with the generator frame and then convert the axieme into welded together.
I hope I've been clear. . .
in the last version there is also the command "full part" that can be useful in cases like this...
