calculate and display polyline length
  • Thread starter Thread starter leon25
leon25
I found a lisp "scrividp" (which allego) that allows to make appear in autocad the size of each segment of one or more polylines next to the segment itself. I have two problems to solve:
- the number of the length that appears has 14 munes after the comma, and I would like to see only 2;
- I would need to see the length of each polyline of the selected group, and not of each segment forming a single polyline.
I don't know if I was clear. Is there something like this between the lisp of this site, or can you help me?
Could be such a thing. not knowing where to insert the text I placed it near the initial summit of polylinea.
As for the 14 decimal digits, they always appeared to me and only 2, whatever the set of decimals in ddunits.
I thank you for the solicity of the answer, but I have to ask if it is possible to make the writings of the lengths belong to a special layer (as in the lisp I sent), so that you can easily manage the properties of the texts.
It should be fine.
Hi, I'm slightly ot but not too much.
If I wanted to change the program because instead of writing those values, it would generate a polylinea
with the same segments (same length, same order) but flattened on the x axis?
rectify a polylinear in short. I tried to study the code of that lisp but I'm a little behind with those functions.
I have difficulty manipulating objects.
Thank you!
hi, I also put myself in this old discussion, if you could add to this lisp also a choice of total polylinear quotation, I would like to see the length.
hi, I also enter into this old discussion, if you could add the possibility of knowing or choosing only the total length.....
for good time work
