calculate weights on iproperties from .jt files
  • Thread starter Thread starter Oriano
Oriano
Good morning to all,
I am developing estimates for customers, and as I normally do, calculation on inventor the maximum weights, I do not need extreme precision for preventive. then I follow with file>iproperties>physical; now I have received files in .jt and I can't do this.
I have already tried to change material but it does nothing, and it does not make me set density , which for deefault remains on 0,000 g/cm3
Any advice?
Thank you in advance.
jt is useless for this activity.
the only option is to use " mesh enabler" and turn the ghost object into solid.
It's a pity that it's a matter for a few pieces, if you have hundreds, you don't end up.
