Fulvio Romano
with an extractor...con un estrattore?
I don't know where to beat. I don't think you can access it. Are the two bearings facing, or maybe not?
The oil is a smart idea, I never came across. . .
here explain the system with pressure oil, but these are uses for very large bearings, electrical power plants stuff:with an extractor...
the system of pressing of oil skf is normally used in all the railway components and not. is a very efficient system that allows to scale with a considerably reduced effort any calettato component with interference (wheels, brake discs, gears, etc.). to use this system is indispensable (via appropriate channel), that oil, painted by a small pump with very high pressure. the system can be used on all components (of a certain size) on which a possible future scale is foreseen.here explain the system with pressure oil, but these are uses for very large bearings, electrical power plants stuff:
http://www.mapro.skf.com/pub/italia...50.230/datiaziende/amos/tipo9/246_247_248.pdf
