gerod
I wanted the eq to be written. depending on an angle!
But the pantographs are like this!
the force is transmitted as a balance of the structure. Imagine a triangle with the hinges in the vertices. you can upload it as you want (but only on the hinges), the triangle will remain rigid without any of the links being pressed down.Is there no bending in the beams? If so, how do you transmit strength between the various elements???? I can't understand... .
I have not followed the reasoning of lucacort, but if it is true, oversize the beams in this way has the same structural logic that multiply the area of the section for the earth-light distance divided lazy for the earthly circumference. . .x lucacort: q load is estimated in that way only to oversize bearing beams
fully agreed. Go on like this.then the fundamental point is: to solve the static of the structure... .
