lo85
Hey, guys.
I ask you a courtesy,
You know how to calculate the cut on the shell plane, I need to figure out a sharp cut panel in its plane, but I can't find the total stress.
How are you doing?
Today a boy explained to me that it is necessary to select for example if I have a panel height 10 meters for a width of 2 meters stressed by a force parallel to the base and modeled with a mesh grid from 0.5m therefore 4x20 square mesh.
to mean a plate attached to the base with a force in the direction of the middle floor (a seismic sect to understand us).
He spoke to me about the concept of integration, or sum all forces parallel to the horizontal sides of the mesh so as to have the cut for each layer of mesh and consequently the maximum at the base.
Doesn't my speech go back to practice?
explain how you calculate flights the cut in the plane of a shell element and how do you adapt it to multiple elements?
How are you doing?
