Brambilla
Hello, I'm doing a reverse project for university on a chainsaw for home use along with 3 other students.
the motor shaft consists of 2 semi-albers connected by force; we imported into ansys workbench the assembly of the two semi-albers in .stp; Informing us around it was recommended (to obtain more realistic values) to insert identical nominal diameters (12 mm) and then set a "connection with friction" and enter a interference value ("offset for the connection surface").
the radial interference between the button and the hole in the sleeve is 0.035 mm. inserting these parameters in ansys, however, the only interference generates a maximum voltage around 1400 mpa: this level is much above the breaking limit for our material (965 mpa - reclaimed steel).
What's wrong with us?
we can not understand if it is a problem of setting in ansys, if the value of interference is realistic or exaggerated (we have tables of the manufacturer, but we have a date for a semi tree and a table revised a few years later for the other tree, if we miss something for the type of internal efforts to the material (traction-compression).
