calculation of surfaces
  • Thread starter Thread starter Liam_82
Liam_82
good evening, I wanted to ask this question, there is a way or function etc. that can automatically write to me the square surface of an environment without having to use the data field function each time.
because then those surfaces I have to put them in a table so I don't have to rewrite the values one by one.
thanks in advance
how does the environment define/delimit?
Are we talking about autocad?
What version?
Some extra details are helpful to those who can/wants to give you an answer.
autocad 2024
I have a floor plan of a shed and will have about 40 environments, I made the polynea that defines the surface of environment/local.
I would like to know if there is the way/function to not have to use the field function present in the text that calculates is writes the square meters. because it turns out to be Moroccan and I have to set for each surface the parameters of the data field.
Also because then those data I would like to bring them back in a table, always autocad so doing de modifiing the surface of a room I also update the table.
I hope to have explained thank you very much
