Lin14
hello to all, they are struggling with the simulation of a frame consisting of 4 beams, two transversal and two longitudinal, which form a rectangle. I have to check the torsion of longitudinal beams. to evaluate the angle of torsion I suppose to be able to use between the outputs the flexible rotation in the final section. the problem is that I can't decipher which angle is what calculates ansys, that is if it is a twist angle or if it calculates the rotation of the whole beam, because I have results different from those I expected, and in addition I have different results if I imposed a remote point in the same point or if I consider the geometry. on the ansys guide is not explained much regarding the flexible rotation. Can you tell me how this command works?
