Cambiare di default i template
  • Thread starter Thread starter New Rider
New Rider
These days I'm playing with nx12. I am trying to customize the various templates and then get to create the files connected with the parameters of the parts.
I tried to start with the template.
I practically made paste copy of the original model. I changed color background, put iso metric view etc. I then went to the scketch preferences of this model and I checked some options like : created automatic quotas I changed the quota label so that I only get out the value etc. I saved the file and repositioned it all via paste copy with the original file in its folder.
now opening the new >model file to draw a new part the view iso metric color has changed but the sketch settings no. what I had modified does not remain apart from color and view.
thanks to those who will be of help.
not all settings are read by the template file.
those that you bring back from them you have to set them from "personalized file-utility-default"
hi axa, of fact turning off a moment I managed to change the propitia as you said from the custom default menu.
Where are you axa? I see you're veined and you're advising.
Hello and thank you
Hello and thank you
Figured, unfortunately I no longer had time to write on the forum, too taken, now with situation, in smart working every now and then I can take a look at it.
We're in a position.
