Apollo0117
in the design of a part, when I have to make the table, I can't eliminate the sampling from the thin walls...I actually found another problem, solid works allows to select the components of the design and eliminate the hair from these only if they were obtained through the nervation command, there is a more general method that allows me to free myself of the sampling from the components that, albeit thin walls, were obtained with the command of simple extrusion?
p.s.
I apologize for the very untechnical jargon, but I do not have much familiarity with the subject. . .
p.p.s.
I don't know what the version of the program used is, but it's not very recent. ..I assume both 2007 at most 2008.
p.s.
p.p.s.
