capricious insertion
  • Thread starter Thread starter ocraM999
ocraM999
family 'capriata con monaco e saette' di revit 2011
What I do not understand is how it is inserted in relation to the reference plan. both have been inserted on level 2undercapriate, the parameters are the same.
Has anyone figured out how it works?
Mar
in other words should become more or less like the red background
I have not yet seen the specific family, but in general, all families have a "basic" reference plan.
As a result the families, when they are inserted into the project, adopt which plan of insertion (= basic plan) the level in which they are performing the insertion.
you must therefore:
- open the specific family (family modification) to check the position of the reference plan with respect to the roe (view of prospectus)
- verified if the position of the reference plan is "compatible" with the reference plan of insertion in the project (for example if the reference plan of the roe is at the top of the monk, when placed in the project, the top of the monk will be below the plan used in the project) or if it is not compatible, you will have to move (in the project) the position of the roe through the offset
- if the family contains parameters, verify that the use of these parameters does not vary the position of the roe from the reference plan (= base plan), and if so, correct the position with the offset
