carcadar map 3d: first steps
  • Thread starter Thread starter maco1999
maco1999
Good morning, I'm praying I never used my autocad map in my life.
I am a technician and since every time I have to present a project I am uncomfortable to find the various maps to be inserted inside, then I tried to install autocad map.
once installed or connected to geoportal data wms. at this point I thought you had digital mappers and so it was possible to save the autocad file (like the common dwg) to reopen with normal autocad and insert the various cartography in the layouts, but I see that it is not so. Can someone tell me how I should do to have different cartography to insert into autocad and then insert into various layouts? thanks to the cartography would be the classics: prg, ctr, orthophotocarta, igm catastale, pai etc... -
Just like you did before... you have to look for them. It's not like if you have autocad map then he works for you. it does not work so
Thank you for the answer but I don't understand.
how did I say once I connected to the wms data and then to video I see the cartography concerned, for example ctr now how do I import this data in normal autocad?
or if you tell me what to do once I downloaded the wms data (ctr, pai etc...) to be able to insert them into a layout, thanks
