cartilage
  • Thread starter Thread starter doriano
Excuse me.
I'm going back to this discussion.
Is there a possibility to save the dwg or dxf of the boards directly all in scale 1:1?
check in the dxf options to have units in mm and not in inch
I tried to set in mm, as before it was set on scale of the drawing, but doing a test does not bring back the scale 1:1.
I'll get you an image...
but do you want to import or export?
if the problem is with 'export, try with a latest dxf/dwg version -> drop down menu
I did some evidence but it doesn't work the same.
I want to save the boards as dwg or dxf, but I would like it to automatically export me to scale 1:1 by saving by name from drawing.
I did some tests setting dxf/dvg 2007 - 2008 but it does not work the same.
Thank you for your help.
