cast iron grill
  • Thread starter Thread starter Geppetto82
Geppetto82
I have to detect a cast iron grille type,
I've got the piece, but I don't know where to start.
We usually take care of mechanical childbirth and I have some difficulty in this case....
Does anyone have any advice or suggestions or have they made similar details?
Sorry but I don't understand the problem.. What do you want/you have to do exactly?
If you have it "in your hand" you will pick up the size and "try" to copy its forms (they are strange and irregular?). First a sketch on paper and then start throwing it down on the cad.
perhaps you mean the modeling procedure (but usually using swx that should not be a problem) to possibly create a mold? or construction methods?
for these things should be seen (and you have it in your hand:biggrin:), maybe put a photo.
Marco:smile:
Hello, Marco.
I didn't explain too well.
My problem is how you say the modeling procedure: it is not very difficult as a piece, but I am accustomed to other types of shapes (pins, trolleys, bushings, etc....) more geometric and "square"!
As soon as I can, I attach two photos.... .
Meanwhile thank you for the answer!
Giuseppe
Here's a preview of what I managed to do so far... .
I also attach 2 photos... .
I would work on a quarter of grid, I create the central body in succession the plan with the supports and in the end the races, very important reforms and fittings once finished the detail and after mirror everything.
when I create the races in the 4 corners tells me that it is impossible because it would generate a geometry with zero thickness..... .
