Casual silence. .
  • Thread starter Thread starter MIRKOLIV
MIRKOLIV
Hello everyone,
someone can tell me how I calculate the total price needed for bending or displacement of a steel pipe dn2" to be applied to a column with a radius of 2 meters...? ? considered the unit price by prezinterRio is about 12€/cad but I can't figure out how many times I have to multiply it. . .
Hello everyone,
someone can tell me how I calculate the total price needed for bending or displacement of a steel pipe dn2" to be applied to a column with a radius of 2 meters...? ? considering the unit price price is about 12€/cad but I can't understand how many times I have to multiply it. . .
Then:
1) present to you.
2) read the rules (where it says it's good not to write capital. )
3)I don't know if you've noticed you're writing in the inventor forum:
What does it have to do with a quote? :confused::cool
Look if there's a special section on cad3d or ask the accountant.
It was enough to say that the bending radius must not exceed 30 times the dn of the pipe....
as you see the accountant has nothing to do with it....!!! ! ! !
thanks to all cmq for helping me solve my problem.. . ! !
I apologize if I didn't read the rules but yesterday I was trying on the internet to solve my doubt and I didn't have much time to read it......(I will immediately try to print a copy and study it properly to avoid offending users again).
greetings mirko
It was enough to say that the bending radius must not exceed 30 times the dn of the pipe....as you see the accountant has nothing to do with it....!!! ! ! !
greetings mirko
I'm sure I've been abrupt, but it remains to be understood according to what we should tell you about that 30-time pipe dn thing, in other words, what are you talking about? ? :confused:
and then it's a fact that this is the section where we talk about questions related to the use of inventors and not about computations.
Excuse me?
You're right... it was a desperate search for help.......!!! !
probably it was hard to explain everything I had in my head.... ! ! !
thanks for the cordiality' cmq...! !
first take the material, it goes so much to the kg... add the embroidery,
then put the cost to the kg of the cut.
for rolling, you should work at 0.30 per kg...
but some dog (as there are few) also works at 200 euros per hour, with machines from 60,000 euros scarce.
for welding... depends on what you have to do.. .
Submerged arch.... and between fixed, direct and indirect costs, you must work at least 60-70 euros/hour.
for speeds consider from 40 cm/min up.
rx 12-15 euro per sheet (useful 400 mm)
for circumferential the number of plates depends on the radiation
If you need to give me a shout, I did these accounts to conclude the thesis where I disassembled and reassembled a department of a company.
then I repeated them in the company where I went to work to buy machinery and bring home the job.
Let's continue to be ot but let me say mine too:
apart from the fact that mirkoliv, from 2012 to today I think it has solved the problems, the fact of working a lot to the kg for the displacement is valid only if you have a machine that works you 8 h/day throughout the year and however 0,30€/kg seems to me few.
Otherwise for non-continuous work I would consider around 50 €/hour for traditional machines, not to control.
however I agree: 200€/hour for the calandratura really barks. ...
I talked to those who sell the machines...and about my pieces he was talking about 0,30 euro/kg.
However, if you consider that a 1500's calandra, which arrives to reach 25 and invite 20, does not exceed 60/70.000 euros, you can not afford to work to 200 euros per hour..... Otherwise, who presents himself with a working center or turning from 600,000 euros,... at what cost should he work?
Sorry for the answer after 3-4 years.
sincerely I didn't even notice (I was also noticed in another post).... I responded with total lightness. Sorry.
