catia v5 r14- add wall tooth on edge
  • Thread starter Thread starter xxfast
xxfast
Hello, everyone.
by little use catia 5.
I can't add a tooth on a wall on edge, in a sheet part.
in sw it was enough to do a sketch on a flange of the edge or change the flange sketch itself.
How the hell do I have to do this?
I'll give you a simple example.
Suppose I would like to make a tooth as indicated in the sketch inserted....
from the profile you have to obtain an additional wall.
I can't do an image of the end of the command, but in the end there's a tangence condition with the adjacent wall, select it.
You mean I have to create another wall?
I'll try.
I feel like I've already tried, but I couldn't.
I'll let you know... .
Okay, it works.
I've done the sketch again, and the tangence came up.
thanks 1000 :finger:
