cava conica con hsm express
TECNOMODEL
I have to work an asola with sloping walls using hsm express on inventor (it is the same present in solidworks)
but if I insert a corner value in the wall no longer compensates the tool but works in the milled center.
Does anyone know how to overcome the problem?
I know that it reasons like the other cams, working in 3d (see the conical wall) you can not use the classic compensation of the 2d (g41/g42 or similar).
normally the 3d is done without compensation, then on some cnc there is also the possibility to compensate in 3d ... but here we go on the complicated.
no, it works in 2d 1/2 then compensates.
only you have to select the lower profile of the pocket.
the reason not to ask me, mysteries of inventor
