karotto
Hello everyone, I'm begging that I'm at an awkward level on revit use. How can I insert a loft so that when I dissect the repeated woodburns come out? In the meantime, do you suggest a course?
You have to use a repeated detail.Hello everyone, I'm begging that I'm at an awkward level on revit use. How can I insert a loft so that when I dissect the repeated woodburns come out? In the meantime, do you suggest a course?
that is probably an object problem. In fact, I remember that there is an elevator object in the library a little bit "ciucco" that needs to be adjusted opening it (the libraries provided with revit are now at the limit of the ridiculous) something that I don't think you are still able to do.thank you, moreover I noticed that changing the size of a lift in 3d does not vary the size of the same in 2d. Forgive me if I am ignorant in the matter. I should follow a course; But now I have to finish this job by a little bit
Thank you, I will enrollthat is probably an object problem. In fact, I remember that there is an elevator object in the library a little bit "ciucco" that needs to be adjusted opening it (the libraries provided with revit are now at the limit of the ridiculous) something that I don't think you are still able to do.
I recommend you sign up for revitcity or modlar and look for an item that works there.
I never thought about it.
thanks tristan, regarding an elevator, of which I can change the size. Can you give me a direct link? Unfortunately I tried to change that of the revit library, but as I have previously written I can change the size. but always remain the same
