centering a text on a line
  • Thread starter Thread starter Alhazred
Alhazred
I am trying to write a function that let me select the ends of a line and that automatically insert a text centered on that line and at a distance fixed by it.
for now I have written this:
Code:
(defun c:centratesto( / pt1 pt2 ang ptc offs puntom)
(setq pt1 (getpoint 1))
(setq pt2 (getpoint 2))
(setq ang (angle pt1 pt2))
(setq ang (/ (* ang 180) pi) ; angle in grades
(setq ptc (/ (+car pt1) (car pt2)) 2.0) ; central point on the x axis
(setq offs (/ (+ (cadr pt1) 0.1) (+ (cadr pt2) 0.1))); central point on the axis y + 0.1 to raise the text from the line
(setq puntom (list ptc offs))
(command "_text" "_justify" "_mc" pointm 0.1 ang "text")
(princ)
but it only works if the line is horizontal, while the line is tilted, the more the writing is close to the line, until it intersects.
How can I get what I need?
Look at the lisp, find 2 versions of your command, centertext is modified for how you thought it, centertext2 is for how I would do it, assuming the use of lines where to place the text.
p.s.: single and rppt functions can be useful on many occasions.
bye
