centrifugal force
  • Thread starter Thread starter AndreaL
AndreaL
Hello everyone, do you know if swx can calculate the centrifugal force of a mass that rotates around a axis? If you like it? I tried to search with the help but without any result. . .
If you can get mass and centerpiece, calculate the " centrifugal force" (which is actually centripetal!) is quite simple. . .
if you can get mass and centerpiece, calculate the " centrifugal force" (that is actually centripetal!) is quite simple. . .
true:finger:.
Let us remember, that does not hurt:biggrin:, that the centrifugal force is a apparent force which exists only in a non-inertial reference system.
you want to explain to those who didn't do physical :angry: "but what apparent force!?! I feel it!!"
we, unfortunately often the senses deceive us, are convinced to understand the forces that surround us and instead not. often we say "but what inertial system you go blathering, because you have to make simple things complicated." because, if you make it simple, then at least the sign is wrong!
so I try to add a result with the formula, I hoped there was a way to view it directly. . .
