change a cylinder
  • Thread starter Thread starter p@po
p@po
as from attached video, I can't tighten and widen the contour.
If I try to move all the edge of the circle.
How come? ?http://www.megaupload.com/?d=9iwsox00
the circle widens only if you move it from its "quadrant" points (4 points on each circle 2 on the x axis and 2 on that y); otherwise it moves
Bye.
but these "quadrant" points where are they?
I only see endopoint and midllepoint on the edge of the circle.
I can't see the attachment, but the curved surfaces cannot be changed. you can only use the scale tool on the entire cylinder.
