change autocad background with gradient color or image
  • Thread starter Thread starter doking
I think you could try like this:1. make sure that, from the management display styles (top left of the work area), the display sile you want to change set, to the background item on
2. access, as previously written, to the background command and set it up.
if you go to edit the dwt file directly these settings will remain for each project.
file --> opens --> "low dwt extension" --> open the dwt you usually use and make the changes.
ciao.
just tried, it also works for those who use advance steel
could you be clearer?
just tried, it also works for those who use advance steelcould you be clearer?
ops, understood
you need to open the .dwt file and then make changes and save
then open new file, copy the .dwt on the desktop and consequently open that them, make changes and I trace it back to the original folder
