doking
just tried, it also works for those who use advance steelBye to all,
I think you could try like this:1. make sure that, from the management display styles (top left of the work area), the display sile you want to change set, to the background item on
2. access, as previously written, to the background command and set it up.
if you go to edit the dwt file directly these settings will remain for each project.
file --> opens --> "low dwt extension" --> open the dwt you usually use and make the changes.ciao.
could you be clearer?
