superbeppe Guest Oct 18, 2011 #1 I have a problem with autocad, I have to transform all the blocks of a same type on a same layer into solid you can do if you like? help me!!!:smile:
Tristan Guest Oct 19, 2011 #2 superbeppe said: I have a problem with autocad, I have to transform all the blocks of a same type on a same layer into solid you can do if you like? Click to expand... edit the block and change the type of restraint in the definition of block.. .
