PSP11
I tried to search for a lisp that allows me to change the color of some selected objects with a value to insert as input. I also looked at the manuals to write lisp but not being practical programming I did not understand how to do, not having found similar lisp that modify a property of objects.
I know that the change is simple to make via the property menu, but when using many colors I would like to avoid having a curtain with all the color styles used by the autocad opening., then a key or a command to insert the color input from the keyboard would make everything much easier and faster.
I hope you can help me. Thank you.
