change color to the lines of a 2d view
  • Thread starter Thread starter volaff
volaff
Good evening,
I would have the need to overlay two views, so I would have the need for one of them to be of a different color than the other.
the only solution I found is to change color to the lines of the view, but unfortunately I had to make it line by line.
Is there a way to speed up the procedure?
Thank you all.
Good weekend.
the method of overlaying two solid views to verify differences between patterns (if this is your purpose) is not optimal. the views can only align them in one direction and therefore it is difficult to have the perfect overlap.
Alternatively you can:
-export in dwg and manage colors and overlap accurately; the procedure must be repeated
- the appropriate commands you find below instrumentssaid that the color is more trivial than it seems.
First of all, we need to create new levels as many views to dedicate a color to.
done this in the feature manager you select with the right button the part or the assieme and leans on character of the compost line
in the tab you remove the tick to use default choice, you choose applica a selection, set up one of the previously created levels
Thank you very much, as soon as I can take a look at the levels on the guide.
Thank you! !
hi volaff, definitely what he said massivonweizen is right, but if you want to color 2 similar sketches, they must be aligned and maybe on 2 separate planes, so you can click them and select "show", at this point from the menu bar clicks "modify-look-colored/short curve...", now you just want to select the sketch to color and choose the color
for view in solidworks means the representation of the model in design environment. then if these must be superimposed it seems rather unlikely to refer to sketches. Moreover in the sketches it is not possible to change color to one line
confuse the terms sketches and views means having a bit of confusion on the program
Masonic excuse, I understood it was in the modeling environment, while it is in the drawing environment then it changes everything, only now I have looked good the title of the discussion, but at least the difference between sketch and view I know it.. .
because you know the difference between view and sketch you should know that the first is related to the design environment. However now volaff knows that he can devote colors to sketches in case he needed (I use this system when I insert the layout of the project to verify that the modeling returns and not confuse sketches of modeling with those of verification)
exact,low receipt,but at least half reply I hope it was useful,at least to change the color of the sketches
(I use this system when I insert the layouts of the project to verify that the modeling returns and does not confuse modeling sketches with those of verification)
,can you explain to me better this phrase,in the sense that I, using mainly powrshape, can place in space 3d a 2d view on a certain level,which I can turn on or off to verify the correctness of model 3d,if you can do such a thing even with solidworks would be fantastic,or I took whistles for whistles?
in practical amount the dwg plant, front and side of the project of the layout study that I use only to verify that the important parameters are respected.
are sketches that are not used for modeling as they are often processed and not always completely accurate. as to clean them keeping the essential is expensive I insert them as they are. At the end of work, I'll take them. to distinguish them immediately from the sketches of modeling, which sometimes I keep visible, the check certain colors
Thank you for your valuable answers.
One more thing to put in the drawer
Good evening and thank you again! ! !
I can try to do the same thing and see if I can, then I'll let you know... practically amounts a view of a dwg for example, will it amount in one part,right?
But it amounts to one part,right?
That's right. if you need to model the part I put it on top of the function tree (however I do not use it to make constraints)
If you need to assemble I insert the part where I imported the views. as the origin may not coincide with the first part inserted, which will be the fixed one, place the layout where it is then necessary to eliminate the constraints created and I also make layout fixed. perhaps a little laborious, but leaves the clean axieme from useless things that could create conflicts or confusion.
It should be remembered that a file with complex sketches with hundreds of lines makes it heavy both at the level of manipulation and at the level of size. for this in the first case should activate layout (by suspending/active part or displaying the sketch) only when necessary; while in the second one must remember to eliminate the layout.
Moreover there is a distinction between these layouts, used only to verify the conformity of the project and obtained from dwg, and those used to construct parameterically with well defined sketches and with a functional logic.
excellent and clear explanation, thank you very much,the thing is extremely useful to me,you are a great.ciao:finger:
Hello Masses, Yesterday evening I tried to import the dwg views and I did as you explained, and it worked very well, thank you, I am happy, hello:wink:
