I need to make captures of seen in catia v 5 r18. it would be convenient to have the white background and not the default blurred blue background, otherwise then I have to discount the objects as well as reach them. Can you help me?
you can also use the tools made available by ca... there is the command on purpose and also allows you to capture the image with white background without having to change it
Thank you! Can you tell me where I find that command to export images? I need them to have a great resolution, so I thought I would do more seen on a 27''', make 200 dpi captures (just because I have typographical needs) and bring together images: the bitmap error will then be reduced and I as the final can have an output in size at least 600 dpi.
If you suggest how the cat does the image, I go to see if it also allows me to decide how many dpi and the type of interpolation it uses to generate the image.
Thank you!
tools -> image-> capture
opens a small window... .
the third button opens another small window where you can select white background (or still set other options). .
Do that the button with the ball snaps your photo that you can save. .
If you look well there are many options... you can take pictures of some areas, all screen or image without tree.. Just make some attempts.
Thanks, now I try if I can get a hyper-defined image.
I've met another problem and asked for it here: I have prepared a simulation with the rotation of an object: if I hold a shaded background the video recorder puts the background behind the object; my need is instead of turning the object with a uniform black background: when I put black as you indicated in the export the film is generated with the white background.
What's wrong?
