change cutting plan
  • Thread starter Thread starter nicoli
nicoli
I can't + change the cutting plan, before it was enough that I approached the plan and clicked on it 2 times , I probably modified something because now on the draft when I approach the cutting plan I can't even highlight the same thing that I was able to do before, some good Samaritan who can unveil the arcane? ? :confused:
1. learn how to write in lowercase print (major print = shout) and first of all read the rules of the forum.
2. Isn't that you're drawing on the background of drawing?? ? ? ? ?
Look, I write in tiny,
the fact is that I did some cutting plans on the draft and now I can no longer change the cutting plan of the various sections that I did, that seems that the cutting plans I had previously made are part of the drawing, before when I wanted to make a change it was enough that I approached the cutting plan and once I was highlighted the cutting plan it was enough that I would click on it two times to be able to change it, now approaching me chess
Did you check that the views are active?
if you use the macro "open dtf" the default views are disactive
Then I repeat to you: Did you check that the "only active level" filter is not selected?
also check that the "top down" option is active.
You did well to tell me why the hell that is,
thank you thank you:rolleyes: thank you thank you:smile:
