change default line styles at table
Tekkasoft
Hello everyone
I would like to change the line style (e.g. the "geometria" pen) by putting a thickness greater than the default one but I would like this not to be done by selecting one for one of the lines involved and then changing the style but that become the default.
for exports (pdf) I created the table.pnt file, setting it in the config file, and it works but I would like to see the right thickness even in the drawing environment.
I searched in the help and forums but found no procedure.
Is it possible? and if yes, how do you do it?
thanks to all
Good job
I do this:
in the config.pro I have:
pen_table_file <mio_percorso>\mio_file_pen_table.pnt
pdf_use_pentable yes
so they definitely use both environments using the same definitions.
But keep in mind that I am still at the Stone Age (wildfire 4), I don't know if something has changed.
to "see" you mean video (how could you do with autocad) or how it is printed from the two environments?</mio_percorso>
Thanks painaz
I use this technique already but it doesn't give me what I want.
with this method you get the correct thicknesses in the exported file "pdf" but not in the environment, at least in my work so (wf5).
Thank you
Hello everyone
thanks to all
Good job
lines in drawing environment are a symbolic representation.
you can export (dxf and dwg) and print with the thicknesses and colors you want but the video representation is that, you can not vary the thicknesses (that I know).
bye maxopus
in fact if you proceed manually you can change the lines with any style, thickness or color you want and have to video that
that you will then see once exported the file in pdf format or other, through the custom pen table .
the need is to make these styles permanent avoiding having to change each drawing by hand.
In the meantime, I'm waiting for someone to know how to do it, as long as they allow it.
thanks the same
