change display of a dynamic block before its insertion
  • Thread starter Thread starter Marco_Udine
Marco_Udine
Good morning.
I ask you if there is a possibility in autocad to change the display of a dynamic block before insertion.
I explain: I have created some dynamic blocks with the various parameters I have also inserted the display. Now, at the time of insertion of the block I would like to be able to change this view before its insertion into the design and not only sucessively to the positioning of the same.
I thank in advance who can help me.
Sure. you have to keep the property palette visible and you will see that in the insertion stage you can change the various parameters, before specifying the insertion point
I thank you first of all for the prompt answer; I checked and actually works. Unfortunately I do not regularly use autocad (I do not agree with their commercial policy ...) and I found another software very similar: bricscad. if 99% of the things work exactly as autocad ... just this does not work ... leaving the palette of the properties open this does not update as soon as I enter the block (and then allow me to change the display).
Do you have any alternatives? Maybe using a keyboard command to change its display? I would also like to attach the sample block... but I think it's too late now... I had to put it in the first chat...
I trust a help from who is more experienced than me...
Thank you so much!
I use gstarcad... but also this software does not fully manage dynamic blocks (at least until version 2023... 2024 I haven't tried it yet!). in practice manages to insert them into the drawing but cannot create them.
