change father part mirrored
  • Thread starter Thread starter Focus
Focus
Hi, I did a research but I did not find anything, for a few days I try to cuff a little with swx but now I'm in trouble and I'm not coming out, I can't change the father of a mirrored part, I'm trying and retrying... how do you do it?
Thank you
explain better please
Don't you find the part?
do not find the body or function?
Not... something else... on body/function/part (specify)?
I have a part 1 from which the part 2 mirrors and leaving it connected to 1, then except by name 3 part 1 and with 4 part 2, I would like the "father of the mirror" of 4, which refers naturally to 2, became 3.
I hope I've been clear
eventually it is about changing the father file of a derivative part with the "specchia part"
menu>apri>selections the mirrored part
in the bottom right you find references, open the tab and change the reference file
It's not clear, but it's very difficult to explain by message.
I have the right solid with its table on the right.
I have to make left with table on the left mirrored.
I do, as you say, copy of the table to the right and hook it to the solid to the right inverting the Father's sight so that it becomes to the left, but it takes the name of the right, and it is not okay, I change the reference and I mirror the part again losing the quotas... Am I wrong?
Wait, I saw the other message now, I'm sorry, I didn't make the configuration......
But wait a minute, if I change the reference file with the left, it tells me impossible to report a file to itself, rightly... So you can't do this or I get it wrong?
incorrect, part 4 remains referred to 1. the change references you have to do it on part 4, replacing part 1 with part 3.
