change fields in the browser
mir
how can you change the data that is displayed in your browser ... besides the name I mean?
ho trovato questo ilogic, rinomina il browser mettendo il n° parte + descrizione
sembra funzionare
sub main
dim asmdoc as assemblydocument
asmdoc = thisapplication.activedocument
shortname=thisdoc.filename(false) 'with extension (false) without extension
' change the name for the assembly.
asmdoc.displayname = buildname(asmdoc)
' change the name in every referenced document.
dim doc as document
for each doc in asmdoc.allreferenceddocuments
oorigrefname = doc.fullfilename
fnamepos = instrrev(oorigrefname, "", -1)'find the postion of the last backslash in the path
name = right(oorigrefname, len(oorigrefname) - fnamepos)'get the file name with the file extension
shortname = left(name, len(name) - 4)'get the file name (without extension)
iproperties.value(name, "project", "part number")=shortname'scrive sul numero parte il nome del file
doc.displayname = buildname(doc)
next
end sub
private function buildname(doc as document) as string
dim new_name as string
dim designtrackprops as propertyset
designtrackprops = doc.propertysets.item("design tracking properties")
new_name = designtrackprops.item("part number").value & " - " & _
designtrackprops.item("description").value
' new_name = designtrackprops.item("part number").value
buildname = new_name
end function
hi I tried it in a set:
system.argumentexception: the 'length' argument must be greater or equal to zero.
in microsoft.visualbasic.strings.left(string str, int32 length)
in lmirulescript.main()
in autodesk.ilogic.exec.appdomexec.execruleinassembly(assembly assem)
in ilogic.ruleevalcontainer.execruleeval(string execrule)
error in the rule: rule0, document: xxxx.iam
Where am I wrong?
Sorry I'm prevented:
sub main
iproperties.value(name, "project", "barcode")=shortname'scrive sul numero parte il nome del file
next
end sub
new_name = designtrackprops.item("barcode").value & " - " & _
designtrackprops.item("descr_partel1").value
end function
Where am I wrong?
here is the sequence
fill out your custom iproperties fields
barcode and descr_partel1
I usually make separate components to exploit copy/paste between the values of the various parts
iproperties personalizzate.webprun the attached ilogic command (download it since I made changes)
_foto__055.webpcan restore values using the rename command from the "productivity" menu
I put on a
messagebox.show(designtrackprops.item("part number").value)
both standard and customized iproperties: I see them all appear correct but nothing changes in the browser.
ps: When you say you run the ilogic you want to create a rule with the code and execute it, don't you? !
ps2: Is there an ilogic manual?
sembra funzionare
sub main
dim doc as document
next
end sub
end function
Good man,
using this code, with the fields "number part" and "description" compiled, modifies the wording of the asses as I would like, but does not do it with the parts below.
Where's the hippo?
use currently inventor 2017
You must omit this command line by adding the apex in front of asm.... .
' asmdoc.displayname = buildname(asmdoc)
Where am I wrong?
Hello, and thank you for the answer.
if I comment the line gives me the same error as the other mentioned post, i.e. problems with lenght.
I probably didn't explain well, I would like that in the browser they would definitely appear on the children "number part" - "description", but if it also appears on the father does not change anything.
I solved this way
'********************'rinomina browser
public sub cambia_nodo()
set asmdoc = thisapplication.activedocument
dim doc as document
next
end sub
dim name as string
set designtrackprops = doc.propertysets.item("design tracking properties")
buildname = name
end function
