PiE81
Good morning.
I should make a change to an isolated surface.
It is a rather extensive surface, but the modification about a small detail.
Attached a screenshot. the part has been realized by applying a thickness to the surface (isolated) that I would like to modify. the modification consists in making the curve end of the particular upper (clear grey) coincide with the similar end of the lower detail.
How do you advise me to proceed?
I know that the question could be trivial, but as a beginner on the subject, I ask your support.
thanks to all
thanks to all
