change materials on multiple pieces
  • Thread starter Thread starter Ale_BTC
Ale_BTC
I tried to do a search in the forum, but I did not find a discussion similar to this.
I'll explain my problem. .
I need to change the material to multiple compiled components in a given folder.
the operation will be repeated several times on multiple folders, to be able to edit hundreds of files.
I'm not good at using macros at all, and I found nothing to do with my case. (but perhaps because of my "incompetence" in the use and/or modification of macros)
I ask you therefore if someone has ever found himself in such a situation and, if yes, how it came out. .
thanks to all in advance
ale
