change of components
  • Thread starter Thread starter Dottor_Scott
Dottor_Scott
and answer my stupid questions:-)
So...
I want to change a component, select the component
and I choose 'assume as the displayed part'. I make my change, I go back to the axieme
(or any drawing board containing the modified part) and I find it
suspended, I have to reactivate it going to put the red 'v' back in the axiemi navigator
can you avoid this behavior? I tried to take a look at
customer default, but honestly I didn't reuse to locate the right option
So...
menu>preferences>assemblies>to him the flag from mantain
the answer has already given you, but I wanted to correct the terms used. the part is not suspended but active in the context of the aid. a part is suspended with the 'suppress' command and you do not see it and is discharged from the ram memory, as if it were not there.
