works
Hello.
I should represent a milling of depth 3 mm on the assembly of our machine tool.This milling however passes through several parts of the assembly therefore I wanted to know if there is a way to change the parts with a unique extrusion.in short I should make a milling on three coupled single plates.
or should I change one by one? ? ?
use solidworks 2009
Thank you very much. .
use solidworks 2009
