change parts in abs
cacciatorino
Good morning to all, a colleague who has no access to the forum asks me to publish this question, if anyone has any ideas he can write to you below and he will read it.
thanks in aticipo!
Hi, I should make an object made in abs more elegant.
I need a surface coating. . I thought about that.
polyurethane paint that makes the surfaces "velluted".
do you have any idea of the technical name of such paints?
I was told that the painting process is called
"pelletization" but sincerely I can only find procedures for
pellet processing.
very used for aesthetic details is a soft touch varnish, creates a rubbery effect on the particular, can be both colored and transparent
I don't know if it's possible ..maybe with desmopan?
I am not informed if it is possible to co-print
It's just an idea that I came by reading the message
Excuse me if I'm allowed. The intrusion.
peace and well
_
I believe it refers to a post-treatment, such as chromiuming.
Abs lends itself a lot to this type of processing, as well as the pc provided you do not use solvent paints .
recommend to contact an excellent company of industrial paints, they definitely can do what you ask
hi ipdesign,
Hello hunter,
I've been out of the press for about 6 years,
But my heart is there,
I meant a rotational co-print with double material,
for the chromed abs,
I had experiences with the control panel of a washing machine,
Abs must be natural and not colored otherwise in the treatment of chrome becomes fragile. . This is my experience,
or maybe you could check if the treatment "cubic"
could be an alternative,
in my own predestined "life" (farm) and also this company
has the cubic sector
thanks for the attention
peace and well
_
