canebao
hi to all I have to create the axieme of a new machine starting from the previous v ersione of which keeps many unchanged components. I hold the two projects in different folders on the pc and at first I create a simple copy of the "old machine" folder and starting from a copy of the old machine axieme I make changes until I get the new machine. Moreover I would like to leave unchanged the names of the components that do not change between the two machines and add a simple suffix on the pieces of the new machine that instead are changed. in the axieme of the "new machine" I have to change all the file paths of the elements that compose it by pointing to the folder "new machine " otherwise the changes I make on the new components go to change the files "old machine". I tried to do it with the command replace components but it tells me that I can not replace an element of the axieme with another element with the same name even if on different folders.
Is there another command that allows me to simply change the file path of each element or do I have to change the names of all the components of the new machine?
