change structure components
  • Thread starter Thread starter diegus
diegus
Save to all, if I use the mechanical structure and then I have in my browser different components, when I double-click on one of these to change it you can only change this without the selection taking also the other components that are nearby?
I don't use the structure (but I like to "discover" someone uses it... maybe later we talk about it better and explain some things to me). .
But perhaps what you ask you could find under the help of mechanical (not autocad) under the heading "mechanical structure, mode of selection". . .
solved! Just select the s-lock button next to the structure button (I had to make it visible through the dx button on the bottom bar), basically with this active mode select only the active component.
I actually use very little mechanical, better inventor :-)
