change table template in progress create 6.0
  • Thread starter Thread starter leleallariscossa
leleallariscossa
Hello everyone,
is it possible in time to change the table template?
I explain: I have custom templates for the tables, I use a3, I realize that I need an a2, I change the format and tac, it enlarges the sheet but I remain the square of the a3 and the folder to move. . I had to customize the format instead of a0_drawing templates etc? thanks
Yes, you have to prepare formats, not templates.
in the templates, insert some particular notes, tables or symbols, which you will need for that design, but for the paperwork, you work on the formats.
I add, the bom tebella, I recommend to keep it external and not bind it to the format, otherwise to the change of the format, the bubble should be remade!
Thank you so much! Can I somehow recover the templates I used to make me the format? to not have to do everything... .
I don't know with creo 6, apart from the square of the sheet (which you do first to remake...), the chart tables, you can save them apart and recover them in the formats.
other things designed ad hoc, try to turn them into external symbols and call them back, but.... Good luck.
e.. say I had opted for the road:
- in the format I have inserted square, chart with fixed texts and logo;
-in the template the parameters defined by user or automatic model using the table casellin with the hidden contour;
Everything works, however, that changing the format in the drawing, updates me everything, but the parameterized notes remain in old position..... what limitation. . .
no, you have to put the parametric notes in the format table, when format changes, it updates everything in correct position.
in the template would be more specific for the table in place (for example I included tables for commercial complexes and in others notes for details requiring a very long text because subjected to particular regulations).
