change the color of the blocks
jim78b
I saw this link of a product http://www.prisma-tech.it/pdf/pms_powerblocks.pdfI judge extremely useful!but paid, does anyone know how to change the color of the blocks without putting them on the zero layer since sometimes you have blocks with various types of lines?
and then here they edit in place, if there are nested blocks you can not change as the command issued block in place is already aviato?
When I need it, I use the "block" color or the block elements take the properties of the layer or color assigned. in the same block you can be objects with fixed color, with layer color and with block color.
to change the nested blocks, make block editors, then you have to choose from the list the affected block
I knew it was so I wondered if there was a faster method! did you see the link of the program? ? ?
