Good morning, please I can't change the shape of a light once it was inserted in the design. Is there any system variable to change?
lightingunits is set to 2
in theory it would also be to activate the shape effect, but in practice doing tests to me does not work, I continue to display a disk (I had never tried to insert linear-shaped lights)
It doesn't work with point light or reflector, I don't understand whether it's a software problem or if I miss doing something.
straight shape (which stands for rectangle) works better than linear but does not provide homogeneous lighting.
I can't even run the function with destination.
I also realized that in the properties lack shadow info, type and form. I think something's wrong.
