change thumb set
  • Thread starter Thread starter xwebx
xwebx
Good morning to all,
I am already a young proe user.
I have a problem regarding the setting of the units of measurement of the designs exported.
the problem arises at the time when I save a design like .dwg and then open it in autocad.
in the proe design the component setting in setup>unita>mm, but then in autocad reads all the measures as if they were in inches and to return the design to the original quotas I always have to multiply for factor 25,4.
how do I keep the file exported directly to mm?
the unit of measurement during construction 3d is correctly set to mm, the problem arises when I use drawing.
where do I change the measuring unit within the drawing?
boys ... the pro/and these things tell you, however also on the forum the topic was treated 1000 times, it would be enough to use the search function.
However when you are in drawing environment, right-click in the graphic area "design options" and opens the window in which to set the options.
when you have set what you need (it also modifies the type of projections that in America are contrary to that in Europe) save the file with the name you want and then indicate it in the config.pro.
