change together mirrored with synchronous command
  • Thread starter Thread starter luca_D
luca_D
good morning to all, how can I change with synchronous commands (setting faces) a mirrored set without altering the original
in solidedge 2024
I don't understand, I'm trying to mirror an axieme and then change the mirrored files massively (setting different faces of different parts) but that do not alter the axieme and the source parts
I didn't understand your needs well.
I am still at r2022 but the commands will be the same (think).
new--> together--please copy together
flag on specular copy
1715577363451.webpunder the options check that the files are renamed.
in solidedge 2024
in the control options mirror together insured, for the parts you want to change, to have set the action on copy and not on rotation
View attachment 71183under the options check that the files are renamed.
thanks now I try, I had generated the copy inside the axieme with the control mirror components
