change undo operations
  • Thread starter Thread starter skeleton
skeleton
Hello everyone,
I would like to know if you can change or customize the types of operations that you can cancel with the undo command.
this because I would like to make sure that the selection operations, empty selection, visible space exchange etc... do not be memorized as cancelable operations since normal operations are performed even without changing the particular in processing.
I hope I've been clear.
hello, thank you for the answer, but I didn't mean the number you can cancel, but just the type of operation, because it seems absurd to me that if I make a selection this is stored in the block of cancelable operations and this also applies to the exchange of visible space and other operations that in my opinion are operations that should not return to that block because they do not change anything.
If anyone has any ideas...
Thanks again
