Sharplook
Good morning, everyone.
as you can guess from the thread title, I need to scale my model in archicad 17. This happened because I drew 1:1 scale, and so far you might think it's okay. but with archicad it happens that when you possibly want to insert any default object, door, window or whatever it is, it is all so tiny that it is not visible.
you will tell me: "Good but change the settings!" However, you will understand that when it comes to changing every minimum measure, from the door frame to the window swing to the finishing of objects, this is impossible. Moreover the textures appear all uniform because precisely, not in an adequate scale. I tried to edit with resizes, but what happens is a resize in plant and not raised.
I really hope there is a solution because otherwise I should remake the 3d (and I have the graduation thesis in 20gg), I have already searched the internet in all languages but it seems impossible, yet it seemed so obvious. :frown:
Thank you very much in advance.
