chart elements in table
  • Thread starter Thread starter Mirko Peverani
Mirko Peverani
Hello is very much that I use create parametric but I never had to insert graphic elements into a table. is it possible to insert a symbol or 2d elements into a table?
you probably know already, but if you run the commands:
- go to the table and click on the right button
- properties selections
- then open or edit from the menu that appears
Maybe you should get closer to what you're asking.
Thank you, but I didn't find anything interesting where you're saying, but I'm pretty sure I've been wrong:
I have to create a table in which within some cells there are illustrative sections, in practice I created the table and with the 2d drawing tools I created sections with exemplifying quotas at the cells.
the table I can save it as a table and reuse but the graphic elements are lost, while if I make a symbol it takes the graphic elements but not the table.
I've never really worked a lot with the symbols and I can't even insert the odds in the symbol... .
I didn't want to go from dxf to not lose formatting. . .
How can I do that?
I had thought of converting the table into 2d elements but I couldn't even in this...
I attach table image for clarity
Hi, you can create a format.
inside put the table and add the symbol.
However it is a format, and then at the design level you can possibly move the table, but not the symbol. .
hello and thanks for the answer, it's a good idea! I think it's the only thing to do... was that a table is more convenient to recall perhaps in drawings already made and to change. . .
