chiudere fori su superfici in 3ds
doraem0n
Hello everyone, you know how I can close holes on the surfaces
of some components of a set in 3ds? (file.max)
if it can be help the file was generated by cad, converted
in step and subsequently imported into 3ds
If the axieme is a polysurface, you can select the hole perimeter to close and use the cap command.
...I also had the same problem....it is not said that cap basti, in fact if it is the problem that I think is due to a fact of not welded thicknesses and surfaces, I recommend: download the demo of rhino 5, import the file the rhino, you import the combined set in 1 block, explode, and here is the magic, you do not explode the individual pieces, but the other assemblies that have been imported esempio ,piu you have to go down in the single detail more ' explodes until you arrive to a series of separate objects between them....if you use max 2014 the import of the cad data improved, in more ' check. from rhino to max via exporting in 3ds I use 2 types of esport 1 for squared objects. ..low poly, and one for rounded parts high poly, however half quality of subdivision surante l export from an acceptable quality..ciao (discussed errors but I am in a hurry)
How do I verify that it is a polysurface?
I don't know 3ds well and these files have passed me
I don't want to be insistent...to do the poly, selections, tdm and convert in polygonal object...but it doesn't solve you...the problem...in case.mandami the file, I take it to you in what you need...radiosity980@gmail.com. or to do it first...and by myself.use rhino 3d....2 click and all you need....p.s Seriously...contact me.. for me it is always a new challenge..and in 15 years of 3dmax....any one wins some....if you lose... hello!!!manda il file se want!!
Thank you very much radiosity but I can't. You know it's business files I can't disclose. cmq I solved. thanks to all for support! ;)
